Haven't ever tested it (never seemed worrisome, I guess), but I think the
first line would move to the second line. IOW the movement would be toward
the line most recently placed.
~Larry
"Diemaker" wrote in message
news:1tvmsvsciqpd4g54edkk7mcaje1nmugdgp@4ax.com...
> >Larry said:
> >Only time I use the fix constraint is when I slap a line down to use as a
> >place to move geometry that would otherwise pull the line to the geometry
as
> >opposed to the geometry to the line.
> --------- Yes, that is my original question, just trying to understand
> the method of the madness. If you draw 2 separate lines and the only
> constrains between them are parallel, then dimension and modify dim...
> which side moves? I understand the effects of constraints, but if
> there were a simple rule like geometry adjust to the positive side
> then I could dimension to avoid driving a sketch out of whack. But
> it's probably not a simple rule and maybe even random. Or smart enough
> to always adjust the side I don't want to move, just to be awnry.
