Inventor Forum
Can not see sketch.
4 REPLIES 4
loafersince89
322 Views, 4 Replies
Can not see sketch.
Just installed inventor on a new PC. When I go to sketch a line it appears to be drawn but nothing is being created. Any ideas?
4 REPLIES 4
JDMather
in reply to: loafersince89
System specs including OS and particularly graphics card/driver.
Did you follow these instructions?
Clean Install
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17955581&linkID=9240617
Did you install Service Pack1?
Try going to Tools>Application Options>Hardware tab and set on lowest setting.
cbenner
JDMather
in reply to: JDMather
If it was the Hardware setting - I would try to download updated graphics card driver and then see if you can go up the list of settings.
evan.vashon
in reply to: cbenner
cbenner,
It seems during my orignal installation something interfered with the generic templates loaded with the program. I was able to get some function when I created my own. The problem was completely solved when i re-downloaded and installed the program for a second time.
No real bug here! Just an anomaly.
Thank you all for the help.
