In the right upper corner of autosek Invetor 2014 is a button wich says New (NEU = German) if i click there the window gets bright gray and says no response (keine Rückmeldung) ... i started the Laptop several times but it never Works.
technical support is not available so what shall i do ?
Reinstall?
Greets Maximilian Dahlenburg
Welcome to the group!
Please post your complete system specs for your laptop. Have you tried a repair or reinstall?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Can you also post a screen shot showing what you are describing?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
