Inventor General
Member
darren.howarth
Message 1 of 6 (326 Views)
Can not extrude a pattern sketch that is fully constrained
326 Views, 5 Replies
01-27-2014 09:15 PM
Hi l am using Inventor 2013 l can not extrude a fully constrained sketch. l done a 2D profile then used the circle Patten command to complete the profile in the sketch. Now l can not extrude the sketch and do not know why? l have attached the file to see if anyone can help.
Any help would be greatly appreciated.
Regards
Darren
Active Member
vince480
Message 2 of 6 (309 Views)
Re: Can not extrude a pattern sketch that is fully constrained
01-28-2014 01:11 AM in reply to: darren.howarth
Is it something to do with your sketch pattern?
Have you closed the loop properly?
If you create a new sketch and project your previous sketch onto this, can you then extrude the projected sketch?
-niels-
Message 3 of 6 (307 Views)
01-28-2014 01:21 AM in reply to: darren.howarth
Welcome to the Forum!
Sketch patterns do not automatically connect endpoints, so you basically have a lot of disconnected loops.
You might try going at it differently, making a cylinder shape first and removing a single "tooth" then make a pattern of that single extrusion.
Using IV2014 Pro SP2, Win7-64bit
JDMather
Message 4 of 6 (296 Views)
01-28-2014 03:58 AM in reply to: darren.howarth
Why did you create the outer arcs as two arcs rather than one?
Edit the sketch and right mouse button select Show All Constraints.  What do you see?
In the browser right click on the sketch and select Sketch Doctor.  Diagnose the sketch and run through the repair.
Is noted - it is (almost) always better to model simple geometry and pattern the feature rather than pattern sketch entities.
I will try to post a couple of alternative techniques later today when I get to my 2013 machine.
Extrude and pattern this.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Member
darren.howarth
Message 5 of 6 (235 Views)
02-24-2014 04:34 PM in reply to: JDMather
Thanks for your help this is a much better way
Member
darren.howarth
Message 6 of 6 (235 Views)
02-24-2014 04:36 PM in reply to: -niels-
Thanks for your help this is a much better way.
Cheers
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
