Greetings!
I am working on a drawing where I have a part that is long and at an angle. I used "Break" to make the view shorter, but because of the lenght of the component, it looks akward (see the attached image). What I was wondering is that if anyone knows of a way to get it done the way I want it to be.
In the attached image you can see what I am talking about. With the arrow I am showing that I want the top part to come down and be aligned with the bottom part. How do I do that? Is it even possible to do?
I am using Inventor 2013.
Your help greatly appreciated!
Best,
-Vadim
Solved by dan_inv09. Go to Solution.
This has been complained about for soooo long.
I'd just rotate the view so the tube is horizontal, it might not be ideal but it's better than what you've got.
dan_inv09,
Like you said, the solution might not be ideal, but it works.
Thanks a lot!
The idea was "accepted" [US19754] in October:
Maybe someone using 2015 can tell us if it made it in, but I suspect it won't be until at least the next release.
Nope...
They "accept" a lot of those.. Then just laugh when we complain 1..2..3 years later and it still isn't in there.
I think "accepted" just means.. "oh this one isn't totally silly"
