I want to insert a spring in an assembly, and for that i will make a spring with the coil command. if i will squeese it between surfaces, will it resemble a spring? will the bindings come closer (i hope they are called bindings, otherwise tell me how they are called)?
Solved by mcgyvr. Go to Solution.
Make the springs Adaptive
or
I prefer to make the length of the spring as a parametric variable and then Animate Parameter in Inventor Studio.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10120912&linkID=9242018
or simply googling "Autodesk Inventor adaptive spring" shows some videos,etc...
