Inventor Forum
Can anyone explain the balloon shape "Circular with 2 entities"
3 REPLIES 3
jpblower
522 Views, 3 Replies
I'm trying to figure out what the additional number in the balloon option "circular w/ 2 entities" represents.
3 REPLIES 3
HI jpblower,
By default this displays the Item number on top, then the QTY, but you can edit the balloon style to change which one displays on top, or to use different  iProperties.
I hope this helps.
Curtis
jpblower
in reply to: jpblower
Thanks.  Is there anyway to override the second number?  I can override the item number but nothing else.
Not an expert by any means but I did do this the other day.  Go into the BOM  and create a phantom part.  Yhen you can edit the balloon to use the phantom part data
