Inventor General
New Member
dorman0351
Message 1 of 13 (2,129 Views)
Can NOT Thread holes with the Thread Tool. Please Help
2129 Views, 12 Replies
03-01-2011 06:20 PM
I can drill a hole as needed, but can't thread a hole at all. Not with the Tapped Hole function when drilling the hole, or after drilling the hole then using the Thread Tool. Inventor will just not let me create threads this way outside of cutting a coil.
If anyone knows why this is happening, what I'm doing wrong, and could help me out, it would be greatly appreciated.
Thanks!
*Pro
Message 2 of 13 (2,120 Views)
Re: Can NOT Thread holes with the Thread Tool. Please Help
03-01-2011 08:04 PM in reply to: dorman0351
Do you have Microsoft Excell 2003 or 2007 on your system? Has it been run once?
Excel is required for many portions of Inventor to work properly.
What version of Inventor are you running?
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
New Member
dorman0351
Message 3 of 13 (2,114 Views)
03-01-2011 09:08 PM in reply to: dorman0351
I'm running Inventor Pro 2011.
I don't have any Microsoft Office products as I use OpenOffice.org.
I went through my registry and made a change that tells Inventor to use Excel or some other Windows program.
Changed it to use Excel, and everything works fine now, even though I don't have Excel.
Appreciate you getting back with me though. Hopefully I don't have to make another post for this.
blair
Message 4 of 13 (2,107 Views)
03-01-2011 10:20 PM in reply to: dorman0351
Even though, OpenOffice can read and write Excel files, there are slight changes to the file handling characteristics. The easiest solution to this would be to install Microsoft Excel as listed in the Autodesk Inventor system requirements.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
New Member
Message 5 of 13 (1,518 Views)
04-14-2012 04:52 AM in reply to: dorman0351
I have the same problem with thread holes, would you mind telling me how you changed your registry to make Inventor use Excel? Thank you in anticipation for your early reply.
Marco Bellante
Message 6 of 13 (1,516 Views)
04-14-2012 04:57 AM in reply to: marco.bellante
See attached.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
New Member
Message 7 of 13 (1,473 Views)
04-22-2012 01:23 PM in reply to: dorman0351
Thanks for the Word doc, fixed my issue!
New Member
Message 8 of 13 (1,447 Views)
04-24-2012 09:08 AM in reply to: dorman0351
Thank you, but I managed to create threads shifting from normal user rights to Administrator rights.
New Member
Message 9 of 13 (1,217 Views)
08-19-2012 02:14 AM in reply to: dorman0351
When I encountered this problem I found that the project I was working with had the "Design Data" project folder option changed.
Some time back, I used the Style Library Manger to create an empty Style Library in a new folder. I then used that empty Style Library as the "Design Data" folder for my project. What I did not realize was that I would lose the
thread functionality when I created the empty style library.
If the "Design Data" folder is not the default folder, the "thread.xls" may be missing. Or as in my case, the "thread.xls" was there, but that it was an empty Excel file.
Since Inventor fails to find any thread data in the "thread.xls" Excel file, it does not allow for the tread option to be selected.
Lesson learned: Never create an empty style library. Always copy the default style library and then modify that copy.
Active Member
olivian.diaconescu
Message 10 of 13 (975 Views)
11-23-2012 01:31 PM in reply to: dorman0351
i have the same problem.The real problem is that my computer are two users.me and adminsitrator.For my account the thread doesn'n work but for administrator  user yes. How could i fix that? There is a solution for my problem?
Best regards,
Olivian
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
