Inventor Forum
Can I use an iProperty as a Parameter WITHOUT using iLogic?
8 REPLIES 8
Message 1 of 9
LT.Rusty
1551 Views, 8 Replies
I know how to get a parameter into my list of custom iProperties, and that's not my issue here.
What I want to do is take the iProperty lbmass and add it to the list of user parameters.  Is there any way to do this without using iLogic?
Rusty
8 REPLIES 8
Message 2 of 9
mrattray
in reply to: LT.Rusty
I don't think so, but it's a very simple thing to do with iLogic. What's so bad about using iLogic?
Mike (not Matt) Rattray
Message 3 of 9
LT.Rusty
in reply to: mrattray
There's probably nothing inherently bad about iLogic, except that I just don't really have the time to spend learning how to use it. 😛
The last time I really sat down to write a lot of code, line numbers were still mandatory.
Rusty
Message 4 of 9
mrattray
It's a one liner. Make the user parameter you want to hold your mass then add a rule with the following line:
myMassParameter = iProperties.Mass
 (Replace "myMassParameter" with whatever you named your parameter to.
Go to the Manage tab > Event Triggers and add your rule an event of your choice. This will control when your parameter updates. I like On Save, mself.
Message 5 of 9
LT.Rusty
Thanks.  I'll play with it some.
I suspect I'm going to just have to learn how to write iLogic code myself eventually.
Rusty
Message 6 of 9
mrattray
These kinds of things are cake. In fact, you could have pulled that line out of the default snippets folder.
Give it a try, they did a pretty good job of making it user friendly to non-programmers.
Message 7 of 9
LT.Rusty
You sort of missed an important part of the iLogic code ...
it's not "mass = i.Properties.Mass." It's "Parameter("partmass") = iProperties.Mass"
This doesn't look that difficult otherwise, I guess. It's something I probably should start figuring out. Bleh.
Thanks for getting me pointed in the right direction.
Rusty
Message 8 of 9
mrattray
You shouldn't need to use the Parameter("patmass"). The only time you need that is if you're using an external rule. Does mass = i.Properties.Mass not work for you?
Message 9 of 9
LT.Rusty
I'm using an external rule.
I've added the trigger in to all my templates, but because I've got a lot of documents that are older than the templates I'm using and I want to be able to run this on those parts as well, I've set it up as external.
Rusty
