Inventor General
Valued Contributor
Andy_Kuang
Message 1 of 6 (114 Views)
Can I supress sketch in iPart ?
114 Views, 5 Replies
03-27-2012 09:33 PM
When I create a configuration in one iPart, I have one Extrusion’s sketch link to another supressed Extrusion and cause problem.
If I can suppress that sketch and I think the problem will be solved.
Andy
Employee
udayag
Message 2 of 6 (107 Views)
Re: Can I supress sketch in iPart ?
03-27-2012 10:57 PM in reply to: Andy_Kuang
You could (indirectly) suppress a sketch created on the face of an extrusion by supprerssing that extrusion. So, a posible workaround is to define the sketch on a surface extrusion, and then suppress the extrusion when necessary.
Udaya Gunasena
Fusion Development
Valued Contributor
Andy_Kuang
Message 3 of 6 (91 Views)
03-28-2012 01:51 PM in reply to: udayag
Hi Udaya Gunasena,
Thanks to have a look at this issue.
When I change my sketch4 on the surface of Extrusion 3 and my problem was solved.
I had been used Solidworks for more than 10 years, Solidworks is different, I’ll try Solidworks at home tonight and may get back to you.
Thanks again.
Andy
Valued Mentor
IgorMir
Message 4 of 6 (82 Views)
03-28-2012 05:37 PM in reply to: Andy_Kuang
Hi Andy,
The sketch is utilizing projected geometry from the previous extrusion, most likely. That's why it's failing. Don't project the extrusion edges. Project sketch geometry instead. That has been discuss on this forum a few days ago.
Igor.
Web: www.meqc.com.au
Valued Contributor
Andy_Kuang
Message 5 of 6 (77 Views)
03-28-2012 08:27 PM in reply to: IgorMir
Thanks mate!
Andy
Melbourne, Australia
Valued Mentor
IgorMir
Message 6 of 6 (74 Views)
03-28-2012 08:34 PM in reply to: Andy_Kuang
You are welcome!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
