Can I place an empty .ipt file into an assembly then start working on it?
Or do I have to create the new part, save it, then go into my assembly and place it?
Thanks.
Solved by Curtis_Waguespack. Go to Solution.
Hi conbuc,
If you go to the Assemble tab and use the Create button, you can choose a template to create an empty *.ipt from and place it into the assembly.
I hope this helps.
Curtis
