I need lock my files. Is it possible?
I would like to edit the file just me and others to have access forbidden. They could read only the file not change anything.
Thank you.
Pedro
Pedro,
Do you have vault? If so you can set the permissions within the vault so as to only you have rights to these files.
If not, permissions will have to be set on the folder structures. Don't ask me how to do that, because that has always been more
of an IT thing in my circles.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
You could go into the file properties and edit the permissions under the security tab. Adjust it so you are the only user with Read-Write privelidges.
