Inventor Forum
Can I import 2d isometric geometry into Inventor and extrude?
5 REPLIES 5
carbonated
465 Views, 5 Replies
It would save me a lot of time if I could do as the title suggests as I received a complex isometric 2D drawing (AutoCAD) from a supplier and need to make 3D models from it.
Thanks in advance
5 REPLIES 5
JDMather
in reply to: carbonated
Yes, but it isn't going to give the results you are after.
Can you attach a sample dwg file here?
carbonated
The file is 4 megs in zipped format so I might as well forget it. Do you know if I can get dimensions off of it? Being an iso, I doubt that they will be accurate.
JDMather
The limit over here http://www.augi.com is 10meg.
A correctly drawn (simple) iso can be accurately dimensioned but because of the difficulty of creating a good iso it is usual practice to fudge. Especially if it isn't simple prismatic edges.
carbonated
I enrolled-so how/where do I post?
http://interlancentral.com Just follow th elink on the home page and read
the instructions...No limit of file size there.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:6019664@discussion.autodesk.com...
