Inventor General
*Expert Elite*
blair
Message 11 of 20 (300 Views)
Re: Can I Split a model in half and then mirror it?
12-31-2012 08:39 AM in reply to: steambc
You are mirroring "Features" that created the body, about a Work Plane and not a cut body. This may work for some models but don't hold your breath for all models.
IV2015 PDSU / Sim Mech 2015 /
Win7-64
EVGA X79 - Classified, iCore7 3930k 32Gb Quad-Channel
950Gb (2 x 500Gb Sata III SSD RAID0 Adaptec 6805E Controller)
Nvidia GTX-690 Classified - 335.23
SpacePilot Pro 3.17.7, 6.17., 4.11
*Expert Elite*
Message 12 of 20 (298 Views)
12-31-2012 09:01 AM in reply to: steambc
steambc wrote:
I should ask, for the sake of understanding what is possible or not, can an existing model be sliced in half, with one half being discarded and the other half mirrored?
Yes.  Slice removing half (or whatever).
Mirror (body, not features) is easiest.
Attach your file here and end all doubt.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
Message 13 of 20 (296 Views)
12-31-2012 09:37 AM in reply to: JDMather
I don't doubt it at all... I just want to know how, since I can't find the elusive "slice" command even though I'm certain it's right there in front of my face!
I'll be at my office in a few minutes and will upload the file. Thanks for taking an interest.
*Expert Elite*
blair
Message 14 of 20 (292 Views)
12-31-2012 09:46 AM in reply to: blair
start a sketch on the surface, draw a bounding box to enclose all that you want removed/cut and use the Extrude command, with the cut option.
Win7-64
Message 15 of 20 (281 Views)
12-31-2012 10:48 AM in reply to: blair
Worked perfectly. Thanks. I knew there had to be a simple, elegant way.
Message 16 of 20 (279 Views)
12-31-2012 10:52 AM in reply to: JDMather
Here's the file. I am a rank beginner and it shows, but I'm getting there. I'm currently doing the CADGorilla tutorials. I did follow Blair's suggestion and successfully sliced the wheel in half and then mirror the body, but here's the file in case you want to look at it.
Thanks again.
*Expert Elite*
Message 17 of 20 (264 Views)
12-31-2012 05:31 PM in reply to: steambc
steambc wrote:
... I can't find the elusive "slice" command even though I'm certain it's right there in front of my face!
In Inventor it is called Split.
Can also be done with Sculpt
or Extrude cut.
Looking at your file I see that you are doing too much work.
You should not have any repeating dimensions for this part and your sketch1 is not constrained.
I recommend you read this document.
Tomorrow I will try to attach example of how I would have done Sketch1.
http://home.pct.edu/~jmather/SkillsUSA%20University.pdf
*Pro
sbixler
Message 18 of 20 (237 Views)
01-01-2013 08:14 AM in reply to: steambc
Ditto blair's and JD's comments regarding basic modeling technique (since I learned from them on this forum, I guess that's a given!).  Assuming that your part is centered on the YZ plane, use the Split tool with the Trim Solid option selected and the YZ plane as the split tool (see Split Tool - Trim Solid.png below).  Then use the Mirror tool with the Mirror Solid option selected and use the YZ plane as the mirror plane (see Mirror Solid.png below).  I think this is what you were asking in your original post.
Message 19 of 20 (185 Views)
01-02-2013 09:52 PM in reply to: JDMather
Thanks JDM.
Yes, I recognize that learning how to be as efficient and elegant as possible is key. I appreciate the tips.
Message 20 of 20 (184 Views)
01-02-2013 09:56 PM in reply to: sbixler
Thanks Sam. That's exactly what I was looking for, the "Split" function, and I knew it was right under my nose. It amazes me how the human brain can prevent the perception of something that is right in front of our eyes.
I took a look at your images and I appreciate your efforts to clarify. I tried it and of course it worked perfectly.
Thanks again to all for your help!
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
