Inventor Forum
Calculation of paint area
2 REPLIES 2
1505 Views, 2 Replies
How can Inventor calculate the paint area of a one-side open container with a double bottom?
The container should be painted at the inside and outside.
But not the hollow space between the double bottom and the real bottom?
Kind regards
Jan
2 REPLIES 2
mpatchus
Two options...
  1. Select all of the surfaces that you want to include, RMB Measure Area.
  2.  Make the "hollow" portion of the double bottom the last element of the part.
Now slide the EOP above the last element and bring up your iProperties.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
JDMather
You could even model the paint and get the volume of paint needed.
Derive Component as surface body and Thicken for the paint.
   (or do as multi-body solid)
What version of Inventor are you using (I can post a 2013 example).
