I just started the Inventor 2014 CABLE & HARNESS tutorials. I set the Project File to tutorial files.ipj. I opened the Cable & harness folder and selected Enclosure_Assembly.iam. I get a message that says "Cannot Read Texture Image". What have I done incorrectly, and how do I fix it? Thanks!
Solved by mcgyvr. Go to Solution.
I think thats an old project file.. and with the changes to the appearance libraries that just has old textures that are no longer used..
Can't you just say "skip" when it complains about the missing textures..
I did a fresh install of 2014 (no other Inventor versions on this computer) and it installs an "interactive tutorials" project and there is no cable/harness tutorial in that.
Or maybe I already deleted the other tutorials project file..
But regardless the enclosure_assembly.iam file is old and probably hasn't been updated with the proper new appearances added in 2013 and forward.
