I WOULD LIKE TO CREATE A I LOGIC RULE THAT WILL AUTOMATICALLY PLACE VIEWS OF AN ASSEMBLY ON TO A DRAWING. I HAVE SEARCHED THE FORUM AND FOUND SOME TOPICS ABOUT THE SUBJECT BUT I STILL CAN NOT FIGURE IT OUT BECAUSE THE SAMPLES THAT I FOUND WERE COMPLEX AND WAS TRYING TO PLACE DIMENSIONS. ALL I WOULD LIKE TO DO AT THIS TIME IS TO PLACE 3 VIEWS AUTOMATICALLY: TOP, LEFT AND RIGHT VIEWS. I HAVE CREATED AN ASSEMBLY WITH I LOGIC AND I WOULD LIKE A PROMPT BOX TO APPEAR AFTER THE USERS SAVE THE FILE IF THE WOULD LIKE TO CREATE A DRAWING, AND IF THE USER SAYS YES THEN A IDW WILL OPEN AND PLACE THE 3 SPECIFIED VIEWS ON TO THE SHEET. CAN ANY ONE HELP ME AND POINT ME INTO A DIRECTION AS HOW TO START THIS.
I am trying to work with this sample code:
Format:HTML Format
Version:1.0
StartHTML: 165
EndHTML: 14402
StartFragment: 314
EndFragment: 14370
StartSelection: 314
EndSelection: 314
SyntaxEditor Code Snippet
ImportsInventor.ViewOrientationTypeEnum
ImportsInventor.DrawingViewStyleEnum
DimoDrawingDocasDrawingDocument
DimoPartDocasDocument
DimoSheetAssheet
DimoTGAsTransientGeometry
DimoView1asDrawingView
DimoView2asDrawingView
DimoView3asDrawingView
DimoView4asDrawingView
ViewScale=3/16
'Ask to create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
IfdwgQuery=vbYesThen
oPartDoc=ThisDoc.Document
'Define IDW Template File Location
oDrawingDoc=ThisApplication.Documents.Add(kDrawingDocumentObject, "Y:\Nemato - Engineering\AUTODESK INVENTOR 3D CAD\Vault Items\NEMATO PROJECT INVENTOR FILES\Templates\NBT", True)
oDrawingDoc=ThisApplication.Documents.Add(kDrawingDocumentObject, "", True)
oSheet=oDrawingDoc.Sheets.Item(1)
'Define 2d view bottom Left corner points For four views
oPoint1=ThisApplication.TransientGeometry.CreatePoint2d(1, 1)
oPoint2=ThisApplication.TransientGeometry.CreatePoint2d(1, 6)
oPoint3=ThisApplication.TransientGeometry.CreatePoint2d(5, 1)
oBaseView=oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 3/16,kFrontViewOrientation, kHiddenLineDrawingViewStyle)', KTANGENTEDGESON)
oView2=oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, 3/16)
oView3=oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, 3/16)
EndIf
but I keep getting this error message
Error in rule: Rule12, in document: Assembly2 (iLogic)
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
I HAVE ALSO POSTED THIS ON THE INVENTOR CUSTOMIZTION FORUM BUT HAVE NOT RECEIVED A RESPONSE AS YET.
You have posted this in the customize section why are you starting another post in here?
http://forums.autodesk.com/t5/Inventor-Customization/PLACE-VIEWS-WITH-I-LOGIC/td-p/4711689
But to take a guess I would say you have no path for the file to go.
opath = ThisDoc.WorkspacePath()
But that is a guess I have not done ilogic for an assembly just parts..
