Inventor Forum
CNC wood in Inventor 2008
8 REPLIES 8
Message 1 of 9
REDHEADEDCHIMP
325 Views, 8 Replies
My problem is I am just starting to do wood items in Inventor. I need to find a way to create a part at a total length with laminate. Then be able to achieve the core without having to make it separate from the laminate.
8 REPLIES 8
Message 2 of 9
in reply to: REDHEADEDCHIMP
so, you want to start off whith the stock laminate? and then cut the final product out?
Message 3 of 9
JDMather
Can you post an example? Thicken Face with Cut option is the first thing that comes to mind. Maybe derive first to preserve the total then Thicken Face for the core.
Message 4 of 9
mflayler2
Is this a good summation:
You would like to create a single part that has information about your stock length as well as the finished cut geometry?
I would approach this with basic surfaces and then turn them off until I need to show them in the production print. This allows me to control the sizing all in one part with equations. Once I get to the production print I can just turn on the surface in the view and change the linetype of the core to represent hidden lines in reference to the stock or however you want to display it.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Message 5 of 9
HUH?
Dave Hoder
Product Design Engineer
idX Seattle
www.idxcorporation.com
IV2008 sp2 Productstream 2008 sp1
Windows XP Pro (32bit) SP2 2GB RAM
Intel Core 2 6420 @ 2.13GH
FX3450 91.36 Driver w/ Open GL
3DxWare 3.5.6
Message 6 of 9
mflayler2
Here is an example:
Very simple but with a complex model other surfacing tools could be used in the same manner. (Thicken / Offset, etc)
Message 7 of 9
are you using melemine material or applying the laminate your self? are you edge banding?
Message 8 of 9
ankersen
I can turn off visibility in the model, but how do I get it on in a drawing?
thanks
Message 9 of 9
mflayler2
Expand the view in the Browser Bar and find the part/assembly; RMB on it and select "Include All Surfaces"
