Inventor Forum
CG in a Drawing
1 REPLY 1
Billduck
763 Views, 1 Reply
CG in a Drawing
Is there a way to make the cg of an assembly appear in a drawing, besides drawing something that does not update?
Thanks in advance.
1 REPLY 1
mpatchus
in reply to: Billduck
RMB on the assembly in the browser and select Center of Gravity.
This will place a crosshair on the CG in that view.
If you wish to use a different symbol for the CG, edit the Object Defaults in the styles.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
