Is there a way to make the cg of an assembly appear in a drawing, besides drawing something that does not update?
Thanks in advance.
Solved by mpatchus. Go to Solution.
RMB on the assembly in the browser and select Center of Gravity.
This will place a crosshair on the CG in that view.
If you wish to use a different symbol for the CG, edit the Object Defaults in the styles.
