Inventor General
Active Member
ddgenifab
Message 1 of 2 (98 Views)
CAN'T RETRIEVE PUBLISH PART IN LIBRAIRY
98 Views, 1 Replies
10-10-2012 08:33 AM
I am trying to publish a i-part to the librairy.  I follow the process and everything and it is suppose to be successful (see attached).  But after that, I can't retrieve this item in the librairy.
Is someone know why.
Using INV 2012 with SP2 installed.
Active Member
ddgenifab
Message 2 of 2 (76 Views)
Re: CAN'T RETRIEVE PUBLISH PART IN LIBRAIRY
10-24-2012 10:22 AM in reply to: ddgenifab
I did a test this morning with Inventor 2010 installed and I am able to publish a part in the librairy.
Doing the same exact thing (same part) with INV 2012 and it do not work !  In both case, the step are the same and I have the "publish successeful" promt.  In INV 2012, I just can't see the part published in the librairy.
Does someone know anything about this?  Is there a SP for INV 2012 for part publishing that I have to install ?
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
