Inventor Forum
CAN'T EXPORT DXF FILES
12 REPLIES 12
Message 1 of 13
BLHDrafting
4918 Views, 12 Replies
Looking for reasons why I can't export DXF files from Inventor Sheetmetal parts.This has only occurred in the last few days.
Error says "Sketch export failed to initialize translator". This occurs when I run either of my 2 DXF macros AND if I RMB on the part Flat Pattern and Export Face As (or something like that - haven't that in a while). The macros lead me to a debug lin of oDataIO.WriteDataToFile sOut, oDXFfileNAME
I have used these 2 macros for 5+ years and have not experienced this before.
Add-ins shows that the Translator: DXF is Automatic / On Demand.
I found an earlier post here (http://autodesk.lithium.com/t5/Inventor-General/Idw-Dxf-conversion/td-p/4294733) but this seems to be loosely related to Avast. I have Trend (server based). Can't remember any new installations of late apart from Flash.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
12 REPLIES 12
Message 2 of 13
BarryZA
in reply to: BLHDrafting
Nope, it was directly related to AvastSmiley Happy
I tried setting exceptions etc. first but nothing helped. System restore sorted it out straight away. I don't know if that was a sledgehammer response, but I was desperate and it worked.
Message 3 of 13
DeerSpotter
IF RUNNING 64BIT GO TO NEW WINDOW or start menu and Run, Copy and Paste the following and hit enter. Follow the steps
1. C:\Program Files\Autodesk\Inventor 2014\Bin\ApprenticeRegSvr.exe
2. C:\Program Files\Autodesk\Inventor 2014\Bin\Bin32\ApprenticeRegSvr.exe
3. C:\Program Files\Autodesk\Inventor 2014\Bin\RegisterPreR10.exe
4.C:\Program Files\Autodesk\Inventor 2014\Bin\RegisterTaskScheduler.exe
Good Luck!
Image and video hosting by TinyPic
See My LinkedIn Profile
Message 4 of 13
BLHDrafting
in reply to: DeerSpotter
I'm running 2013 so I was able to do all except step 3 as it couldn't find the file. I eventually located it in and ran that :-
D:\Autodesk\Autodesk_Inventor_2013_English_Win_64bit\x64\Inventor\Program Files\Autodesk\Inventor 2013\Bin\RegisterPreR10.exe
(C: is an SSD for the OS and Inventor/Vault (for speed). 😧 is for other programs and data. I'm not sure why the above file is in D:)
Initial testing showed the problem was not fixed.I then copied the file found in 😧 to the folder in your steps and re-run all of the files. Further testing showed the problem was not fixed.
Brendan Henderson
Message 5 of 13
bob_holland
I think that Inventor is not fully registered.
Please follow the steps in the attached PDF.
Bob Holland
Autodesk Product Support
Message 6 of 13
BLHDrafting
in reply to: bob_holland
Bob, did as the PDF instructed (replaced 2014 with 2013). No good. Still can't export/save as DXF. Same error message (Sketch export failed to initialize translator).
Brendan Henderson
Message 7 of 13
bob_holland
Brendan,
Please try the following:
The steps are as follows (Please substitute as appropriate for your version):
  1. Exit Inventor
  2. Open Regedit
  3. Rename
    1. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version
    2. HKEY_CURRENT_USER\Software\Autodesk\Inventor\Current Version.org
  4. Rename
    1. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0
    2. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion0.0.org
  5. Rename
    1. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0
    2. HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion18.0.org
  6. Exit Regedit
  7. Rename
    1. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014
    2. C:\Users\USERID\AppData\Local\Autodesk\Inventor 2014.org
  8. Rename
    1. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014
    2. C:\Users\hollanb\AppData\Roaming\Autodesk\Inventor 2014.org
  9. Start Inventor and test.
Note:
RegistryVersion18.0       =          Inventor Release 2014
RegistryVersion17.0       =          Inventor Release 2013
RegistryVersion16.0       =          Inventor Release 2012
RegistryVersion15.0       =          Inventor Release 2011
RegistryVersion14.0       =          Inventor Release 2010
Bob Holland
Message 8 of 13
BLHDrafting
Bob, I followed the instructions except for step 7 where I could not find USERID (I'm thinking it is a generic entry where I need to substitute my name for USERID). Restarted PC and Inventor. Tested and still not working from RMB on Flat and Save As or from macros.
Brendan Henderson
Message 9 of 13
BLHDrafting
Correction : I did complete all steps including step 7. I'm having a bad day 😞
Brendan Henderson
Message 10 of 13
bob_holland
Brendan,
Can you save to DXF for other parts?
In so, please either post your part file or private message it to me.
If you can't create a DXF file for any parts please have someone else login and test it.
If it works for them, then you have a damaged user profile.
If not the application is somehow not fully installed.
Please let us know either way.
Bob Holland
Message 11 of 13
BLHDrafting
Bob, on the same PC I logged in as another user and I can export the DXF without any problems.
This is the first time this user has logged onto the machine. Is there anything I can copy from this new profile into my regular profile to fix the problem? Or is there some other fix? I'm at the point of thinking about re-install as this is crippling me.
I have installed or un-installed something that has screwed up an otherwise perfect production machine. I have had no issues exporting DXF files via macro's or RMB and Save Copy As since Inventor 10. The only thing I can remember installing recently is FreeCAD, Google Desktop and Adobe Reader XI.
Brendan Henderson
Message 12 of 13
bob_holland
Brendan,
By being having work logged in as a different user, it tells me the issue is with your user profile.
"C:\Program Files\Autodesk\Inventor 2013\Bin\Inventor.exe" /unregister
"C:\Program Files\Autodesk\Inventor 2013\Bin\Inventor.exe" /uninstall
Please run these from a command prompt.
The /unregister will cause a CER. that you can ignore.
Let is finish before you run the /uninstall.
Let me know how that works.
Bob Holland
Message 13 of 13
BLHDrafting
Bob, I just finished a re-install of Inventor 2013. Initial testing shows the error is fixed. Both macro's and RMB "SAVE COPY AS" all work.
Many, many thnaks for the input you and the others have provided. I'm buggered if I know what caused a perfect production machien to go haywire, but I really don't want to go through that again.
Brendan Henderson
