I have a huge problem with my assembly file.
Whenever i want to delete or change the position of an Object there is this error message:
"Internal Error in stability process(Post restore of Object 000007FFFA39DE70 meta-type RDxRefSpline3 in segment PmDCSegment ends up causing a cycle)"
I restarted my project 5 times now and it keeps appearing randomly. Sometimes in the beginning, sometimes in the end, sometimes when I restart inventor(Autodesk Inventor 2014)
I redid all my parts to make sure there is no problem with one of them but there is no way i can avoid it.
Please Help me to fix my project! I dont want to start all over again and again.
Patrick
I am just allowed to add 3 attachments to a message, can i give you a dropbox link via pn or something like that?
ahh sry i forgot about that
I had to split the .zips because one file would be have been above the limit.
I reproduced the issue. I logged defect DID1518365 and we will look at it.
Jaroslav
Hey there,
I have the same Issue! Do you have a Solution yet? Would a re-installation fix that problem?
Julian
I found the solution for my issue!!
The bevel gear was broken, I just deleted and readded it.
Problem solved!
anyway, thanks for your effort to help me! 😃
