Inventor General
Active Contributor
KFrankenberger
Message 1 of 10 (1,126 Views)
Breaking dim extension lines as they cross over other dim extension lines...
1126 Views, 9 Replies
11-29-2011 07:54 AM
I'm using Inventor 2011 and I can't figure out how to set my dimension settings so it breaks the dimension extension lines automatically when crossing over other dimension extension lines.  I saw that others say it just happens, but it is not "just happening" for me.  Can someone explain how to set my dimensions so when dimension lines cross each other one of them automatically breaks?
Thanks.
*Pro
sbixler
Message 2 of 10 (1,104 Views)
Re: Breaking dim extension lines as they cross over other dim extension lines...
12-04-2011 05:49 PM in reply to: KFrankenberger
In 2011 (and 2012), extension lines only break around dimension text.  I've never seen them break around other extension or dimension lines.
Active Contributor
KFrankenberger
Message 3 of 10 (1,089 Views)
12-05-2011 10:05 AM in reply to: KFrankenberger
That is unfortiunate. So I guess there is no way to break them? In regular AutoCAD (haven't used it in a while but I used 2008, I think) you exploded dimensions and could adjust them however you wanted after you exploded them.
Employee
Message 4 of 10 (1,068 Views)
12-07-2011 06:47 AM in reply to: KFrankenberger
Hi, there was a logged a WISH item for that (DID#924303). I have added your comments to the defect.
Ladislav
Active Contributor
KFrankenberger
Message 5 of 10 (1,058 Views)
12-07-2011 08:22 AM in reply to: t_pcoll
Does that mean next time they make a new version of Inventor they might consider adding the ability to explode dimensions so you can break dim lines around each other manually?
Message 6 of 10 (1,038 Views)
12-07-2011 10:24 AM in reply to: KFrankenberger
actually, there is "dimbreak" command in autocad for that :smileyhappy:
Active Contributor
KFrankenberger
Message 7 of 10 (1,034 Views)
12-07-2011 10:42 AM in reply to: vakhtang
Is there a "dimbreak" command in Inventor for that? I couldn't find one.
Message 8 of 10 (752 Views)
11-15-2012 08:19 PM in reply to: KFrankenberger
still waiting for the solution is it available in 2013
Message 9 of 10 (323 Views)
09-27-2013 01:52 PM in reply to: prem
Nothing so far that I find in version 2013.
Perhaps by the next century Autodesk might hire a programmer who has actually taken some kind of drafting class.
*Expert Elite*
Cadmanto
Message 10 of 10 (315 Views)
09-27-2013 02:16 PM in reply to: enigma
Have you tried searching in the Inventor IdeaStation to see if this has been suggested?  If you cannot find anything there, create one.  I know the guys at Autodesk monitor there.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
