Inventor General
Member
Message 1 of 9 (296 Views)
Accepted Solution
Break out view glitch with frame generator components
296 Views, 8 Replies
02-15-2013 03:29 AM
When creating a break out view on a top level assembly that includes frame generator components, the break out function does not break these parts out. I know it is working because the non-frame generator parts are disappearing and being broken out as you would expect but the frame generated parts seem to be immune to the command. is this a common fault or something wrong with my particular model?
Can anyone offer some help or a work around?
*Expert Elite*
Message 2 of 9 (270 Views)
Re: Break out view glitch with frame generator components
02-15-2013 09:02 AM in reply to: jaanos
I'm not sure but, could it have something to do with "Section Participation"?
(Section Standard Parts on the Drawing tab of Application Options - in the Options area of the Tools tab on the ribbon - and/or right click on the part in the browser for the view on the idw)
*Expert Elite*
Cadmanto
Message 3 of 9 (255 Views)
02-15-2013 12:46 PM in reply to: jaanos
Sounds like you might be talking about an assembly drawing.
If that is the case edit the broken out view and select this setting.
See if this does the trick.
Best Regards,
Scott McFadden
Inventor Professional 2014
(Colossians 3:23-25)
Message 4 of 9 (92 Views)
02-05-2014 02:37 AM in reply to: Cadmanto
Yes. This solution works a treat. Had this problem for a while, sorted now. Thanks Scott. :-)
*Expert Elite*
Cadmanto
Message 5 of 9 (83 Views)
02-05-2014 05:42 AM in reply to: steve.west
Steve,
I am glad it worked for you.  It can be frustrating trying to find certain settings that give you what you are looking for.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Message 6 of 9 (79 Views)
02-05-2014 05:51 AM in reply to: Cadmanto
Agreed. I should also point out that Dan_inv09 offered a solution that also works. In some instances, the break-out view is required to reveal other details that are also part of the same 'Frame Generator' assembly, so globally changing the view settings using Scott's method also hides the parts you are trying to reveal. In this instance, you have to find the offending parts in the browser and select them for 'Section Participation' individually. Takes longer than Scott's method but is the only way in this scenario.
*Expert Elite*
Cadmanto
Message 7 of 9 (69 Views)
02-05-2014 05:56 AM in reply to: steve.west
Thanks for the explanation.  Like the old saying goes, there is more then one way to skin a cat!!!  :smileyvery-happy:
Best Regards,
Scott McFadden
Message 8 of 9 (67 Views)
02-05-2014 05:59 AM in reply to: steve.west
To true. I think if everyone gets involved in posting their experiences, it helps everyone who encounters the same problem.
[cid:image002.jpg@01CF227A.59B655F0] Best Regards
Steve West
Design Engineer
Tel: +44 (0)1384 453966
Email: steve.west@alltherm.co.uk
designers & manufacturers of thermal processing equipment
*Expert Elite*
Message 9 of 9 (54 Views)
02-05-2014 08:19 AM in reply to: steve.west
Application Options saves you from having to change it for every base view.
(I thought maybe you could make a drawing template that would override it but it looks like Application Options trumps settings you may have made for that before saving as template.)
I prefer "Obey Browser Settings". The only problem is that it does not automatically section the "standard" parts (you can change it at the top level of the assembly though).
I wish there was a way to tell it that you would like to be able to control it in the browser but it should not default to not sectioned.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
