Inventor General
Valued Mentor
Ktelang
Message 1 of 4 (227 Views)
Break View at an Angle
227 Views, 3 Replies
06-25-2012 11:51 AM
Hello Everyone,
Any trick to make create a break view along a sloping edge.
So that the view still appears continuous rather that the one
shown in attached pic.
Config :: Intel (R) Xeon (R) CPU E31245 @ 3.30 GHz, 16.0 GB, 64bit win7
Inventor 2013 and Vault Basic 2013
Curtis_Waguespack
Message 2 of 4 (217 Views)
Re: Break View at an Angle
06-25-2012 01:05 PM in reply to: Ktelang
Hi Ktelang,
Unfortunately it isn't possible, but it has been requested in the past. You can add your feedback at the Autodesk feedback link:
You can request enhancement and new features using the Feed Back link:
http://inventortrenches.blogspot.com/2011/01/feature-request-for-inventor.html
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Valued Mentor
Ktelang
Message 3 of 4 (211 Views)
06-25-2012 01:48 PM in reply to: Curtis_Waguespack
Thanks Curtis
New Member
mechdsn
Message 4 of 4 (133 Views)
01-14-2013 10:29 AM in reply to: Ktelang
A possible "work-around" would be to break the views alignment to its parent view and then rotate the view to a horizontal or vertical orientation. Then, you can use the break view command as normal and add the angle of rotation to the view label that was generated automatically. I would typicallly add something like "VIEW ROTATED 60 CCW" (counter clockwise). Most shops can work with that without too much confusion. It would be great if Autodesk would allow broken angled views in the next release though...
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
