Thanks Mike. I repaired it though I am not sure exactly what I did that
solved the problem. In Part 3 per your keen eye, I opened the Parameter and
clicked in the Quation edit box of d2 (0.405) an arrow pops up and I clecked
it and went to Tolerence. Once there I changed the precision to 0. and the
Evaluate Size to Nominal. I saved and updated everything with NO change. I
then opened Part 3 again and Edited Feature on Flange 1 and typed in AGAIN
.405. Updated/Saved again returned to the Assembly and IT WAS CORRECTED.
Thank you for spotting this. I do not think that I would have ever seen it
and I am not sure how I fixed it but it is fixed now.
Is this TRULY OPERATOR error or Software? I can handle either answer being
correct. If it's me....I'll learn. If it's IV it'll be fixed. I would
just like to know which.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
(Remove All Numbers From E-mail)
"Mike Maenpaa" wrote in message
news:FCADD852793B78182CB63A885601F672@in.WebX.maYIadrTaRb...
> Look at Part3 new_reva.ipt, open up the Parameters dialog. The dimension
has
> .405, but also has a tolerance dim of .4045 for Nominal & Model. I haven't
> tried tolerance modeling yet, so I'm not sure how to change that. I think
> that's where the .001 is coming from.
> Mike
> "Keith_Bradford" <7kbradford7@7scsfrigette7.com> wrote in message
> news:C82E21031B85769DE62CC4CBD796804E@in.WebX.maYIadrTaRb...
> > Yes I am wondering why it is off by .001.
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
> > news:B86B14AA821E31C9BE4D0E6B57FB30A1@in.WebX.maYIadrTaRb...
> > > I noticed that too. On one part, the edge selected for the flange is
the
> > > inside edge. On the other part, the outside edge is selected.
> > > Keith, are you wondering why it's off by .001?
> > > Mike
> > > "Kent Keller" wrote in message
> > > news:AF260166F91B6BE666734D85BF88B105@in.WebX.maYIadrTaRb...
> > > > Keith
