Inventor General
Member
Uppy
Message 1 of 4 (100 Views)
Bom renumbering
100 Views, 3 Replies
06-18-2012 12:40 PM
I have a list of 20 parts on my bom and item 3 is missing. For some reason there is an item 71 on the bom ...... How do I alter item 71 to read item 3? Many thanks
Curtis_Waguespack
Message 2 of 4 (98 Views)
Re: Bom renumbering
06-18-2012 12:43 PM in reply to: Uppy
Hi Uppy,
This link should help:
http://wikihelp.autodesk.com/Inventor/enu/2012/Help/0073-Autodesk73/0460-Assembli460/0530-Bills_of53...
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Cadmanto
Message 3 of 4 (85 Views)
Re: Bom renumbering
06-18-2012 01:55 PM in reply to: Uppy
You can RC on the BOM and select "Edit Parts List" then manually change the item numbers in question, then at the resequence the BOM by item number.
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Member
Uppy
Message 4 of 4 (76 Views)
Re: Bom renumbering
06-18-2012 02:08 PM in reply to: Uppy
Cheers .... Fairly new on this so maybe asking 'simple' questions
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
