I haven't used bolted connections much but have started giving them a try. I have found, however, that if I make any changes to the parts the bolted connections show up with the lightning bolt symbol (marked for update). I would expect the hole positions to automatically update once the changes to the parts have been made. I tried a rebuild all - Didn't get rid of update symbol. The only way I have been able to "update" the connection is to "edit using design accelerator" and simply select ok. Changes are then applied and the symbol disappears.
This can be "dangerous" for less experienced users who come to modify and existing design, they may change a driving sketch which determines hole position, save the sketch and not realize that the actual hole positions haven't changed.
Safest method would be an automatic update...
Anyway to do this?
Solved by mflayler2. Go to Solution.
If you right click on the Bolted Connection there is an option in one of the flyouts in that menu I beleive under Component>Automatic Solve
This is turned off by default and has to be manually turned on for any DA components and is mostly a memory saving issue.
Mark Flayler - Engagement Engineer
IMAGINiT Manufacturing Solutions Blog: https://resources.imaginit.com/manufacturing-solutions-blog
Mark,
I've opened a ticket for an explaination of all the right-click, Component options related to BC's. Why do the symbols change? What EXACTLY does each option do?
Hi! I don't believe so unfortunately. I I will work with the project team and see if it can be done.
Many thanks!
