Inventor Forum
Bolted connection follow pattern not work
6 REPLIES 6
rgruychev
1253 Views, 6 Replies
Bolted connection follow pattern not work. When i use  follow pattern  in Bolted connection  component not pattern
6 REPLIES 6
cbenner
in reply to: rgruychev
In your picture, I see all of the holes highlighted... looks like it's following the pattern.  That screen shot doesn't show the completed process, does it not insert fasteners in all of the highlighted holes?
JDMather
Feature pattern or Component pattern?
Attach your assembly here.
The CADWhisperer YouTube Channel
rgruychev
JDMather
Your holes are placed at the assembly level, not at the part level.  (open part and there are no holes)
Is this what you intended?
rgruychev
in reply to: JDMather
How use command follow patter when i have holes in assembly level?
craigzcool
in reply to: cbenner
Im having  a similar problem... its shows the wireframe view as though its going to place multiple screws in the assembly, but when i click apply, It places all the multiple holes but only shows 1 bolt on the first refernce that i choose. why does it not place all the bolts when placing the holes.
Thanks, Craig
