Inventor General
Distinguished Contributor
rgruychev
Message 1 of 7 (491 Views)
Bolted connection follow pattern not work
491 Views, 6 Replies
06-13-2012 01:03 AM
Bolted connection follow pattern not work. When i use  follow pattern  in Bolted connection  component not pattern
cbenner
Message 2 of 7 (483 Views)
Re: Bolted connection follow pattern not work
06-13-2012 04:04 AM in reply to: rgruychev
In your picture, I see all of the holes highlighted... looks like it's following the pattern.  That screen shot doesn't show the completed process, does it not insert fasteners in all of the highlighted holes?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
JDMather
Message 3 of 7 (478 Views)
06-13-2012 04:12 AM in reply to: rgruychev
Feature pattern or Component pattern?
Attach your assembly here.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
rgruychev
Message 4 of 7 (471 Views)
06-13-2012 05:47 AM in reply to: rgruychev
JDMather
Message 5 of 7 (465 Views)
06-13-2012 06:28 AM in reply to: rgruychev
Your holes are placed at the assembly level, not at the part level.  (open part and there are no holes)
Is this what you intended?
rgruychev
Message 6 of 7 (458 Views)
06-13-2012 06:48 AM in reply to: JDMather
How use command follow patter when i have holes in assembly level?
craigzcool
Message 7 of 7 (396 Views)
10-11-2012 06:40 AM in reply to: cbenner
Im having  a similar problem... its shows the wireframe view as though its going to place multiple screws in the assembly, but when i click apply, It places all the multiple holes but only shows 1 bolt on the first refernce that i choose. why does it not place all the bolts when placing the holes.
Thanks, Craig
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
