All of the sudden I cant get to my bolted connection dialog box.
1. The command runs and the prompts at the lower part of the screen show.
2. Have loaded and unloaded / restarted via add ins.
3. Have looked behind all windows ect on both of my 2 screens
Anything else to try?
Thanks!
What version of Inventor? Do all your other dialogs work fine? Has anything changes since it last worked? Is the COntent Center loaded and working? (just reaching now....)
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Have you tried this with Inventor being the only program running?
Have you tried the Alt-Tab key stroke that toggles through the programs to see if that triggers it?
See if this thread helps you.
Are you using dual monitors?
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Ian,
Can you tell is if it works if a different person logs in?
Please post an update.
Thank you.
Hey,
I'm running the trial version or inventor, I have been using it heavily for the last 5 days and used the bolted connection tool many times. All of a sudden today I am having the same problem in the subject line - the dialog box simply wont appear. I get the prompts to select the face, hole and termination point but there is no dialog bog present anywhere.
