I recently upgraded to Inventor 2015 and everything was working fine, up until now. I am trying to insert bolted connections using the concentric tool and every time I do it, the preview looks fine. They are all in the correct holes and at the correct orientation. However, as soon as I click ok, the bolts flip to 90 degrees and move so they are no longer even near the holes. I tried to do bolted connections by holes as well, and for whatever reason it wouldn't recognize any of my holes. I did it in a smaller assembly with just one part to test it, and the bolted connections worked fine.
Post a screen shot of what you are seeing. What are you connecting with BC? Are the holes already in the parts, and how were they modeled? As holes, or as extrusions?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I originally had them as extrusions that were already in the parts and had this problem. I changed them to holes to see if that would help and it did not have any effect. As I stated previously, it wouldn't recognize them as holes either when I tried doing bolted connections by hole.
