I've lost my Bolted Connection Templates... you know, the pre-defined bolt-washer-nut selections available for re-use at the bottom of the Bolted Connection dialoge box.
Did I lose or over-write a file? What file do my Bolted Connection Templates live in?
John
Solved by jdavis417. Go to Solution.
Oh, it's 2012 !
(...not simulation... Design Suite?)
I was trying to think of what had changed recently and I DID have to delete my windows-user profile and re-create it to solve some "oddness" that Inventor was doing... could I have pathed myself away from my previously-customized file?
Thanks again,
John
Who made the templates? And where was they placed. You could do a search for .xml files and look to see if you can find them. But if you don't know I would not they don't come pre loaded they are made and saved.
I created the previous "templates"...
I made a new "test" template and (finally) found it here...
C:\Users\...\AppData\Roaming\Autodesk\Inventor 2012\DesignAccelerator\Templates\CABoltCon
I think I have a backup of my previous "templates", but will have to do it in my "spare time".
I'll try post back here if I find any exceptions or anything that might help others who may have to wipe-out their Windows Profile, as I did.
John
