Inventor General
Active Contributor
nickhowe
Message 1 of 6 (418 Views)
Bolted Connection Component Generator Problems
418 Views, 5 Replies
04-27-2012 12:05 AM
Hi
I have been using the bolted Connection utility and have found that it takes a long time accessing the content centre (up to a minute) for the fasteners. Sometimes it flashes the fasteners window up for as millisecond and then cancells it. Is this a bug?
Cheers
Nick
Active Contributor
nickhowe
Message 2 of 6 (414 Views)
Re: Bolted Connection Component Generator Problems
04-27-2012 01:26 AM in reply to: nickhowe
....also I'm having trouble seeing all of the folders through the generator even though I can see them all when i place from the Content Center.
For example I have three folders of types of washers, the Component Generator only offers me one type from one folder.
It's driving me insane!
cbenner
Message 3 of 6 (403 Views)
04-27-2012 07:42 AM in reply to: nickhowe
What version of Inventor?  Is your Content Center Vault or Desktop?  Can you attach a screen shot of what you are seeing in the BC Generator that doesn't look right?
ChrisB
Please use Mark Solutions!.Accept as Solution &Give Kudos!Kudos to further enhance the value of these forums. Thank you! :smileyhappy:
http://cbennertipstricks.blogspot.com/
Active Contributor
nickhowe
Message 4 of 6 (383 Views)
04-30-2012 11:45 PM in reply to: cbenner
Hi Chris
Attached a couple of picxs showing the problem. The Content Center is a modified desktop center (soon to Vault) for our use with alternative fixing descriptions that required us to "turn off" the other standards. We just arent seeing the whole of the library left over when using the "bolted connection" tool.
Cheers
Nick
Active Contributor
nickhowe
Message 5 of 6 (379 Views)
04-30-2012 11:58 PM in reply to: nickhowe
Sorry, also to mention. The speed issue cleared up with the deleting of most of the standards. I expect it was trying to form a Vault link or something.
Regards
Nick
Valued Contributor
alh-alliedmin
Message 6 of 6 (229 Views)
05-10-2013 04:19 AM in reply to: nickhowe
I'm seeing the slow down as well on all of our workstations.
And the one workstation that connects from farther away is having the the same empty or missing standards issue.
We use Vault as the Content Center.
Any news yet?
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
