Inventor General
Winks87
Message 1 of 5 (407 Views)
Bolt assembly descriptions in a parts list
407 Views, 4 Replies
07-25-2012 08:50 AM
At my workplace it has been standard practice in Autocad to call out bolt assemblies in a parts list as: 1/2-13 unc hex hd. bolt w/flat washer & nut.  Has anyone figured out how to do this in Inventor?  I know I can enter this info on the assembly iProps for the bolt assembly, I was hoping someone came up with an automated format, maybe pulling info from the bolt itself to populate the assembly iProps?  Any info/suggestions greatly welcomed!
James Winkler
Product Design Suite Ultimate 2014
Vault Professional 2014
Windows 7 Pro SP1
HP-Z400: 2.67 GHz 12 Gb Ram
Nvidia Quadro FX1800 driver 276.42
*Pro
jletcher
Message 2 of 5 (402 Views)
Re: Bolt assembly descriptions in a parts list
07-25-2012 08:59 AM in reply to: Winks87
you can use ilogic to do this easy. as long as it is set up from the get go. Do you use content center hardware or do you have a lybary?
When you insert a bolt nut wash ect.. is it an assembly or parts brought in?
Are they ipart hardware?
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Valued Mentor
mpatchus
Message 3 of 5 (399 Views)
07-25-2012 09:17 AM in reply to: Winks87
We have built standard bolted assemblies for our most commonly used configurations and placed them in our library.
This way everyone is using the same assebmlies, and the descriptions come in the same way everytime for everyone.
Mike Patchus
Inventor 2012 SP3 ~ Vault Pro 2013
Lenovo D20 Workstation Intel Xenon E5640@2.67GHz (2)
Win 7, 24gb RAM, NVIDIA Quadro FX 3800
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. :smileyhappy:
Winks87
Message 4 of 5 (372 Views)
07-26-2012 05:03 AM in reply to: Winks87
Currently, we bring in standard content center parts with bolted assembly.  I have no experience with iLogic yet, but  I am willing to experiment as long as it is not complicated for the users.  We have multiple users and would like an easy solution for the end users.  I would be open to iParts or iLogic.  We will be upgrading to 2012 soon and would be a good time if I need to modify content center or create new libraries if needed.  What is involved in the iLogic route?
James Winkler
Windows 7 Pro SP1
Product Support
bobvdd
Message 5 of 5 (347 Views)
08-07-2012 01:54 PM in reply to: Winks87
Not sure if iLogic will help you at all because we disable iLogic rules inside Bolted connection assemblies.
Here is a another thought. If you place below macro in your VBA Application project , select a bolted connection first and then run the macro, you will get a string similar to what you want in the Description property of the bolted connection subassembly. Of course this is far from being automatic (only works on one bolted connection at a time and has to be repeated if the composition of the bolted connection changes)
By using the "-" string as separator between each individual component's description, I was able to come up with overall description strings like:
ANSI B18.2.2 - 1 1/2 - 6-Lock Washers (Inch Series)Extra-Duty Helical Spring Lock Washer-Heavy Hex Bolt-Washer A-Hex Nuts (Inch Series) Slotted Hex Nut
or:
DIN 6924 - M4-Hexagon Socket Countersunk Head Screw-Spring Washer-Hex Nut
Option Explicit
Sub boltnaming()
Dim assydoc As AssemblyDocument
Set assydoc = ThisApplication.ActiveDocument
Dim partdoc As ComponentOccurrence
Dim lastdoc As ComponentOccurrence
Dim enhanceddesc As String
enhanceddesc = ""
' Check to make sure a sub-ssembly is selected.
If assydoc.SelectSet.count > 0 Then
If (assydoc.DocumentType <> kAssemblyDocumentObject) Then
   MsgBox "A bolted connection must be selected first."
   Exit Sub
Else
  Exit Sub
Dim subassydoc As ComponentOccurrence
Set subassydoc = assydoc.SelectSet.Item(1)
Set partdoc = assydoc.SelectSet.Item(1).Definition.Occurrences.Item(1)
For Each partdoc In subassydoc.Definition.Occurrences
Dim partdesc As Property
Set partdesc = partdoc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description")
enhanceddesc = enhanceddesc + "-" + partdesc.Value
Set lastdoc = partdoc
Next partdoc
Dim partnumber As String
partnumber = lastdoc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
subassydoc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Description").Value = partnumber + "-" + enhanceddesc
End Sub
Cheers
Bob
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
