Inventor General
New Member
houtchenswho
Message 1 of 4 (922 Views)
Accepted Solution
Bolt Circle Centerline to Non-Circles .idw
922 Views, 3 Replies
12-04-2012 08:20 AM
I have a ratchet plate idw that I've drawn and dimensioned, but I would like to insert two bolt circles to the two diameter dimensions that appear to be pointing at nothing. The circular pattern is not made up of circles so I haven't been able to use the Centered Pattern command in the centerline section. I'm using Inventor 2013.
*Expert Elite*
JDMather
Message 2 of 4 (918 Views)
Re: Bolt Circle Centerline to Non-Circles .idw
12-04-2012 08:23 AM in reply to: houtchenswho
Either
Retrieve sketch from ipt
or
click on view and hit S on keyboard.
Project Geometry center circle and two points on teeth.
Sketch circles.
Exit sketch.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
New Member
houtchenswho
Message 3 of 4 (903 Views)
12-04-2012 08:59 AM in reply to: JDMather
I would like to mention that after creating the circles, I had some trouble formatting them to centerline, until I realized this option was under the right click menu in properties. Thank you
*Pro
sbixler
Message 4 of 4 (855 Views)
12-05-2012 05:01 AM in reply to: houtchenswho
The other method to change line styles is while you are in the sketch, change to the Annotate tab and select the approriate layer in the Format panel.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
