I have an assembly consisting of both sub assemblies and individual parts.
When I insert the bill, it is only showing me the parts and assy's needed to build the assembly.
Is there a way to have it list the sub assemlies and then their lower level parts, with quantities?
Thank you for your help.
Solved by cbenner. Go to Solution.
In the BOM editor, select Structured. Right click on the tab and select View Properties. Then set it to All Levels and choose a delimiter for the sublevels and parts.
Then when you place your Parts List, go into the Prats List Editor and on each top level right click and choose Expand All Children.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Thank you very much!
That is almost exactly what I was looking for.
