Inventor Forum
Bill Of Material
3 REPLIES 3
JoelMckone
328 Views, 3 Replies
Bill Of Material
Is there any way to create a seperate BOM for different views?  I can create a BOM for each but changes in 1 are duplicated in the second.
Tags (2)
3 REPLIES 3
mcgyvr
in reply to: JoelMckone
It comes down to exactly what you are trying to do.
Please remember that a BOM is used in the assembly but a parts list is used on a drawing.. The are similar but there are differences.
For example you can use design view reps and then filter the parts list to only show the parts in that design view rep (but the bom has everything)
Or you can create iassemblies where your BOM (and parts list) would be different based on different configurations.
JoelMckone
in reply to: mcgyvr
Creating BOM using views doen't help as whle the parts on the same, cut lengths vary.  The easiest solution was to do a 'save as' and create unique assemblies for each option.
msklein
HOW about filtering by ballooning. Show only parts ballooned. should do what you want. makes no sence to me, but gets you what you want.
MSK
