Hello
Im trying to render out pictures from Inventor but the quality is not what I espected
I have the maximum settings in the rendering window and also the maximum dpi (300)
The PC is good with an NVIDIA Quadro 2000 graphic card
Is this really the best Inventor can do or what do I need to do to get better quality?
Solved by Mark.Downes. Go to Solution.
I think inventor does not really do 300 dpi.
I encountered the same problem before.
As I worked for print media before I am
sure about it.
There should be an option do define size
and resolution seperately. That´s when a
dpi setting starts to make sense.
As I could not work out a direct solution
I took the files to Max or Showcase as I
have licences of those programs available
at work too.
The AA setting in Showcase is a great im-
provement already and it seems to output
pictures withe the right resolution too.
With Max you can virtually do everything.
Even though assigning and editing mate-
rials take some time, and lighting does too,
you can get photorealistic renders for any
purpose.
If you have a picture editor capable of using
layers you might enhance your image by
using overlays with different render styles.
I got some nice results by that.
Won´t be helping you with the resolution,
but it´s worth a try when it comes to looks
I guess.
Kind regards
Daniel
Thankyou!
I have tried different resolutions settings but nothing really push up the quality.
The pictures will be used for print media
I dont like Studio Max at all....Not userfriendly at all for newbies like me! 🙂
I am strictly an mechanical enigeer and works alot with Inventor/CAD so I like to use any tools within Inventor.
If Studio Max is the olny way to get good pictures I guess I need to check it out!
Any other suggestions?
Hi Mustange69
You should be able to get a half decent screen capture by applying the materials for your part, set your view to realistic (Good setting works fine for me), let the screen render.
Then go to File> Export> Image> then adjust the options (bottom of screen) set x=0 y=0 to a larger size (say) x=4000 y=3000.
Hope this helps
Cheers
Mark
Inventor 2013
Now we get there!
Works pretty good I will try around with this!
Thankyou!
Hello there,
you can easily calc the real dpi of a picture
and it´s size in print dependent on the dpi.
http://auctionrepair.com/pixels.html
Might help you when you know the target size
of the image.
Kind regards
Daniel
Hola Emaiolino,
I made a crib sheet last year for this, if you follow the attached pdf you should be able to follow it ok.
Post an image to let us know how you got on
Cheers
Mark
Inventor 2014
Dear Mark, good morning.
Thank you very much for the reply and input!
I will perform the tests and upload an example!
Best Regards
Dear Mark,
Excellent explanation! Very grateful! I used to apply it in a weldment (IAM) with the same principles of du detail. The sample:
