Inventor Forum
Best way to share parameters between parts in an assembly?
1 REPLY 1
bcadenza
608 Views, 1 Reply
If I have parts in an assembly that would like to use the same parameter, what is the best way to do this?  I am using AI 2013.  Currently I know how to create a base part and using it to derive other parts from it, but this seems there should be a easier way, is there?
Bob
1 REPLY 1
rhasell
in reply to: bcadenza
Hi
The method I use it to link my master part in the assembly. (Similar to derive in part mode)
- Click parameters.
- Select Link
- Change file type to *.ipt, *.iam
- choose file
you can then choose the parameters you wish to use.
Hope this helps.
Reg
2024.2
Please Accept as a solution / Kudos
