I have attached a pdf of a part I'm working on in Inventor.
I am needing the joggled area to be vertical, as it's shown on the pdf.
I tried using the flange, but it follows the bend line.
I appreciate any suggestions, etc. you have.
Solved by japike. Go to Solution.
I am still using 2012, but from what I am readiong this is still not an option in 2013.
You can add jogs to odinate dimensions, but not linear dimensions.
Is ordinate dimensioning an option for you?
I'm not to the drawing stage yet.
I'm trying to find the best way to model the joggle into my .ipt.
Hi sps_cad_guy,
There is an example part file attached at this link that might help:
http://forums.autodesk.com/t5/Autodesk-Inventor/Help-making-sheet-metal-part/m-p/3658008#M451116
I hope this helps.
Curtis
Wow, I am so sorry. I really missed the mark on this one.
Have you tried using the sheet metal tools? Specifically this one?
Thank you all for the help.
This is exactly what I was needing to accomplish.
Thank you so very much for your help.
