Inventor Forum
Best format for neutral file format for exporting/importing 3D files
13 REPLIES 13
Message 1 of 14
blair
4771 Views, 13 Replies
What is the best export/import format for sending 3D files. I need someone to send be neutral format files, possibly Solidworks but I am not sure. Also any export settings to make sure I get decent quality files.
Nothing like getting a surface model when you want solid model.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
13 REPLIES 13
Message 2 of 14
MariaManuela
in reply to: blair
The best neutral format is STEP file.
Asidek Consultant Specialist
www.asidek.es
Message 3 of 14
mpatchus
in reply to: MariaManuela
Agree... we've had great success since using only STEP files.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Message 4 of 14
blair
in reply to: mpatchus
Thanks, just what I thought.
Delta Tau Chi ΔΤΧ
Message 6 of 14
mrattray
in reply to: blair
My vote is for step, as well.
Mike (not Matt) Rattray
Message 7 of 14
-niels-
in reply to: blair
I'll go with STEP as preferred neutral format too.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 8 of 14
mcgyvr
in reply to: -niels-
STEP hands down... I've had a few random problems with IGES... Never a problem with STEP
Message 9 of 14
sam_m
in reply to: mcgyvr
To be the black sheep, I tend to use IGES with our toolmaker (who uses Solidworks).  On the first project we worked together they had problems importing the STEP file I created so I tried IGES and it worked better; so we've stuck to that since...
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 10 of 14
mrattray
in reply to: sam_m
When I ran SolidWorks I preferred step files.
I have found though that certain geometries for whatever reason don't like certain formats; sometimes you just have to try something else to get it to translate right.
Message 11 of 14
stephengibson76
in reply to: blair
I recall looking into this about 6 years ago and the data at the time suggested 20% of translations between kernels would have errors...  Just doing a quick LMGTFY to see if I could find the data and came across this interesting blog
http://blog.grabcad.com/2013/05/kernels-why-cad-systems-dont-play-well-with-others/
Stephen Gibson
View stephen gibson's profile on LinkedIn
Message 12 of 14
blair
in reply to: stephengibson76
Nice,
thanks,
Delta Tau Chi ΔΤΧ
Message 13 of 14
Olivia_v_Doorn
in reply to: blair
I mainly use .obj, i never had trouble with that, so you might want to try that 😛
Message 14 of 14
WHolzwarth
in reply to: blair
I've seen a few cases where SWX didn't import well for STEPS from Inventor. A Parasolid (x_t, x_b) did it.
Filesize of Parasolid is normally smaller than STEP. But in most cases I'm using STEP, too.
Walter
Walter Holzwarth
