You would think this would be an easy google search but it appears not...
Whats the fastest dual core CPU for Inventor?
eg would an i5-2390T@2.7 really be 20% faster than an i5-680@3.6? as some of the benchmarks suggest
is it worth looking at server processors so I can fill up lots of ram slots with smaller more ecenomical ram?
If you mean buying a complete server 'machine' instead of a workstation I'd guess it's a bad idea. Maybe more ram slots but you'd have to pay $$$s for graphics upgrade.
Good question. I don't think there is a Inventor specific benchmark. Maybe this site will help.
http://www.cpubenchmark.net/high_end_cpus.html
make sure you are looking at a chart with the "per core" speed. And you are aware that 2012 supports multicores in the idw environment now right? and I'd expect modeling areas to follow (hopefully shortly)
I knew 2012 supports multi core for SOME idw functions but testing my current slower quad core against another faster dual core, the dual core still performs better in the drawing enviroment.
(specs from the top of my head, q6600 @2.4 against dual core @ 3.4 or 3.6)
I was under the impression that they need to re-write the program from the bottom up to include multi core functionallity in the modelling enviroment which is why none of the parametric modellers have taken the plunge. I thought this was years off, so the ROI on an expensive multicore processor would be poor.
I would really like some solid information about this, I dont have much time to investigate fully and may be wrong
Autodesk still does hardawre testing for Inventor. The last time I checked, the top three were 1) HP XW400, 2) XW600, and 3) XW800. The XW400 beat systems with better specs because it had the highest clock speed.
