Hi.
I am new to using Autodesk Inventor.
I want to know if you can make the simulation of sheet metal bending, I'm designing a bending die, and I need to simulate the folding.
thanks for help.
Francisco Pineda
Solved by Dan_Margulius. Go to Solution.
Hi
In the Studio environment you can animate parameters(dimensions like angles).
Look for examples here in the forums.
There are some.
Hope it helps
Dan
