il giorno 13/12/2007 11.35 MarcoA ha scritto:
> P.S. Applying the dacal after bending is worse...
That was not completely exact.
I succeded to make it work, but I had to make the image the exact size
of the flange. If bigger, it doesn't work.
Furthermore, I found how to achieve good quality in decals without
using embedded images in MSWord files. I share it hoping it helps
other people.
I had to scale the image to the right dimension AND to a resolution of
96 dpi, that seems to be the resolution to which images are inserted
into Inventor.
I used to insert bigger images and then to scale them within the
sketch, but this give an awful quality result.
M.
