Inventor General
Contributor amd
amd
Message 1 of 5 (497 Views)
Bending An sheet metal part
497 Views, 4 Replies
10-25-2012 02:06 AM
Hi friends,
I want to bend the sheet metal part as on 90deg
I have tried using bend and Fold tool but it dose not produce the right model as desired.
please let me know if you have come across any situation like this before & how to overcome
Kindly refer to the attachment for the screen shot  of the part
thanks & Regards
Contributor amd
amd
Message 2 of 5 (496 Views)
Re: Bending An sheet metal part
10-25-2012 02:08 AM in reply to: amd
the inventor file can also be found in the atachment
Distinguished Contributor
Mark.Downes
Message 3 of 5 (484 Views)
10-25-2012 03:38 AM in reply to: amd
you can model this with the contour roll command first, then an extrusion.
See attached 2013 inventor part
Cheers
Mark
*Expert Elite*
JDMather
Message 4 of 5 (454 Views)
10-25-2012 06:42 AM in reply to: amd
Where did you get the image in your attachment if you don't know how to create the model?
BTW - Dan Banach's part can be done using only sheet metal tools, you don't need to Extrude.
Look in Help for Rolled Contour and Contoured Flange.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Mark.Downes
Message 5 of 5 (426 Views)
10-25-2012 07:44 AM in reply to: JDMather
Hi JD,
I have just re-created the sheet metal part emulating your work flow after seeing your feature history tree picture, so much easier than my first attempt. All these little things make it easier in our day jobs.
Many thanks
Mark:smileyvery-happy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
