Inventor Forum
Bend Part Command Isn't Working
3 REPLIES 3
830 Views, 3 Replies
I'm not certain whether or not inventor refuses to bend the part based on the complexity of the geometry,
but I even tried simplifying it and it still won't work.
The part is straight and exactly the length necessary to make a 90 degree curved tube with a 50mm radius (from centre of bend to centre of torus).
(π100)/4 is the length of my tube. =~78.54
Can someone please help me to bend this part 90 degrees with a radius of 50mm from the centre of the tube to the centre of the bend?
3 REPLIES 3
JDMather
Something like this?
in reply to: JDMather
That's exactly what I needed. Thank you so much.
I do have one question though.
I suppressed the feature that you added, and did it again using a center line at the bottom of the tube like you did.
I changed all the settings to the way you bent it, but mine keeps on warping out of position like before.
I'm thinking my Software might just be buggy today.
Thanks again.
JDMather
@Anonymous wrote:
.... mine keeps on warping out of position like before.
Thanks again.
Attach your "warped" file here.
