Hello, does anyone know any rule to replace the annotation direction bending, as attached image, I thank all who help.
Solved by theo.bot. Go to Solution.
Try this:
'loop tru all bend notes
For Each oBendnote In ThisDoc.Document.ActiveSheet.DrawingNotes.bendnotes
'clear previus text overrides
oBendnote.text=""
oBendnote.hidevalue=False
'check direction and set note
If oBendnote.text.Contains("DOWN") Then
otext= Replace (oBendnote.text,"DOWN","BAIXO")
oBendnote.text= otext
oBendnote.hidevalue=True
ElseIf oBendnote.text.Contains("UP") Then
otext= Replace (oBendnote.text,"UP","CIMA")
oBendnote.text=otext
End If
Next
don't forget to set a event trigger to run this rule for updating your notes, because now it's a text override.
succes
Hi Do you know how to get the bendnote to show with ilogic ? without having to select the line.first.
Cheers,
Hi tony.yates,
See this link:
I hope this helps.
Curtis
