Inventor General
Member
Message 1 of 3 (219 Views)
Bearing drawings with unsectioned rolling elements
219 Views, 2 Replies
11-28-2012 08:24 PM
I am trying to make a standard sectioned drawing of a shaft with bearings. I understand the rolling elements of the bearings are not to be sectioned. The rest of the bearing, however, must be sectioned. I cannot find a way to make that happen. Does anyone know?
The bearing I'm using is from the content center. I can only choose between sectioning the bearing or not section it, I don't have that option anymore when it comes to individuals parts of the bearing.
Thanks.
Marvin
Active Contributor
jonathanruffray
Message 2 of 3 (176 Views)
Re : Bearing drawings with unsectioned rolling elements
12-03-2012 04:49 AM in reply to: marvinm
In your drawing, select the hatches of the ball and then right click => mask.
John.
Autodesk Product Design Suite Ultimate 2013
Win 7 Pro 64 bits SP1
Bi-Xeon E5520 (2x Quad-core @2.27GHz)
Quadro Fx 1800 768Mo GDDR3
6Go Ram DDR3 667MHz ECC
karthur1
Message 3 of 3 (168 Views)
Re: Bearing drawings with unsectioned rolling elements
12-03-2012 05:27 AM in reply to: marvinm
In the idw, right click on the view >find in browser.  Now over in the browser, find the element that you dont want included in the section. Right Click on it Section Participation>None.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
